CREO 12.0.0.1 Config Issues
Brn_The_Admin
Is anyone else having config control issues with this new Creo+ update? All of our config options pointed to Windchill are broken and half of the others arent working correctly. I know PTC wanted to move all these option to the Creo portal but it seems like alot of things were not accounted for. Having to individually go into each of our company profiles and update the config since the global config option doesn't work is one thing we've run into. Anyone have any thoughts on this? Or workarounds?
PTC Support has proposed a fix in an upcoming Creo release. Resolution is TBD.
Hi @Brn_The_Admin,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
please report the problem to PTC Support.
Martin Hanák
