To all,
Anyone seen the release that is due out today M090? I have checked the download site at various times since this morning and no beuno!
Buddy ![]()
Installed here and kicking the tires on it here. The save issue of M080 does appear to be fixed.
That is a target date... the actual date varies ![]()
Antonius, no offense, but they should release it on the actual date they say on the product schedule...
Yeah Antonius!!!
hehe
Just received confirmation from an engineer @ PTC. Officical release of M090 has been pushed to the 27th.
Thanks for the heads up, Bryant!
I knew I'd find a use for this image someday...
I've been told the team has updated that date to December 29th, 2013.
Figures.....same story...
It's more important that the update be "ready" than it is to be on time. It seems as if M080 wasn't ready but released anyway.
Steve
I am just very disappointed in the fact that PTC continues to make the same mistakes over and over and over again...how hard is it to get this right? My management, I assume like many others are rattled by the inconsistancy of this product and how so many bugs are just "acceptable"...PTC needs to be the standard for CAD, not the one people constantly complain about....
Ok its the 27th, where is the download?
Ryan has inside scoop... and said it would be the 29th.
And count on it being at the the COB (close of business).
Hense, a Monday morning download flurry.
Just checked - M090 is now available for download:
Update....but the download fails because it's not really available (at least for me it fails saying the file isn't there).
I get a page that says "not found" on all the choices. Must be in process of being available ![]()
Yeah, me too. But M080 has been relatively soild for me. For the first time, I am not sure if I will go to M090 right away. I'll have to read through the change notes.
I'm holding out for M090 because it is suppose to fix a pattern bug I reported earlier.
Still on M040 for now.
Yep, I am getting the "Not Found" page also Antonius.....
Page found! Downloaded!
got it, but now I can't find the release notes comparing page. ![]()
(update advisor) https://www.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
yeah that! thanks.
And did you install it? ![]()
Not yet. It's one of those "dread" things ![]()
Ok Antonius, I just installed m090...How about you?
Not yet, Matt... been a bit pre-occupied in the last few days.
I hear ya, I was not going to install it because m080 has run so well, but I had a couple issues the other day, so I decided it was time. So far so good, but only been a couple days of use.
