CREO 3.0
shaanmech
CREO 3.0
Is creo 3.0 available for 32-bit systems..?????
Yes, it is.
There are separate installation packages for Windows 32-bit and Windows 64-bit.
Martin Hanak
Martin Hanák
Yes it is.
But it has been recommended that you switch to a 64bit system, due to the memory switch which allows you to run more memory.
It will perform better
