CREO 4 installing :: KERNELBASE.dll error
bence
2-Explorer
Hi Everyone,
I'cant install CREO! :-[
When I press Install on the screen it sits it freezes.
I don't get any error message.
I found this at Win 10 log file:
- Event 1000, Application Error
- setup.exe_Creo
- modul: KERNELBASE.dll (version: 10.0.18362.535)
- exception: 0x0000025
Dell Inspiron 3542
- processor: 4th Generation Intel Core i3-4 005U processor (3M Cache 1.7GH z)
- videocard: NVIDIA(R) GeForce(R) 820M 2GB DDR3L
- hdd: 500GB 5400rpm SATA 6Gbs
- ram: 4GB Single Channel DDR3L 1600M Hz (4GBx1)
- network: Dell(TM) Wireless 1705/1704 Dr iver
- operating system: Win 10 Pro, Hun, up-to-date
I have already tried:
- disable Win firewall and Defender
- disable / enable: integrated and Nvidia video card
- disable / enable: lan and wifi
- check KernelBase.dll: no problem was found
- upgrade / downgrade: video cards driver
- change regional settings to US
- of course I followed the official installation manuals
- I experienced the same issue with CREO 4, 5 and 6.
Anyone have any ideas?
Thanks :-]
Mahesh_Sharma
22-Sapphire I
(To:bence)
@bence
What is OS language?
You may try renaming the folder for installation media to some English name.
6 REPLIES 6
MartinHanak
(To:bence)
please describe the steps you have taken in detail.
Martin Hanák
bence
2-Explorer
(To:MartinHanak)
Hello Martin :-]
1. PTC Creo 4.0 DVD image: www.ptc.com/appserver/auth/it/esd/academicFree.jsp
2. unzip to my desktop
3. run install.exe
4. installation freezes
Thanx!
MartinHanak
(To:bence)
@bence wrote:
Hello Martin :-]
3. run install.exe
Thanx!
I think your step 3. is ... run setup.exe ...
What Windows 10 version do you use ?
Windows 10 32-bit or 64-bit ?
Please run ipconfig /all > ip.txt command in Command Prompt window and upload ip.txt file. Sometimes network card can cause problems.
Martin Hanák
bence
2-Explorer
(To:MartinHanak)
<< I think your step 3. is ... run setup.exe ...
Yes, you are right!
<< What Windows 10 version do you use ?
Windows 10 64bit., Professional version, Hungarian, up-to-date
<< Please run ipconfig /all > ip.txt command in Command Prompt window and upload ip.txt file.
I have tried to enable / disable  / configure all of my network cards.
Mahesh_Sharma
22-Sapphire I
(To:bence)
@bence
Window 10 Pro Hungarian and up-to-date.
I ran it from c:\test\ end It has helped me.
Problem is solved!
Thank you very much! :-]
