HI all,
For evaluation purposes, I want to install CREO 8.0.
However my company uses CREO 7.0.2.0, java 8_301 as well as WINDCHILL 11.1
I figured out that for CREO 8 I need Java 11.
Can I install Java 11, run my tests on CREO8, and continue to work alongside CREO 7.0.2.0 to troubleshoot my users?
Regards
Hello @Dom_BOUCHARDY
I'm part of PTC Technical Support, but not covering usually this part of our applications. Consider therefore what follows as a willingness to help (as @VladimirN raised my attention on this), but if you want to have the official answer from PTC Technical Support, please open a case to us from here.
Regarding your question, and just illustrating my answer from what I can see in our official documents, without knowledge in this area then:
Again, take above information with caution (not an expert here once again), and feel free therefore to open a case to us if you would like to get official views from PTC TS.
Serge
Serge
Hello everyone,
Thank you very much for your very fast response, this community is awesome 🙂
I went through the PTC documentation before posting, but didn't get a clear answer so I asked you.
@sacquarone: thank you for your explanations, very clear and accept your suggestion to open a ptc file.
Regards
Dom
Thank you, Serge!
What I do here is download the java 11 jre runtime zip file from https://adoptium.net/ and extract that into c:/ptc/creo_parametric-8.0/java.
Then set environment variable PRO_JAVA_COMMAND=c:/ptc/creo_parametric-8.0/java
If you want something "officially" supported then do the same for Amazon Corretto java jdk zip file.
