CREO Layout 3.0 : How to change arrow style ?
msauthier
8-Gravel
Hi everyone.
Does anybody know how to change arrow style in CREO Layout 3.0.
I've tried to change the parameter "arrow_style" in the iso.dtl file or prodetail.dt file. Without any success although it works in a CREO Parametric drawings.
As CREO Layout uses the same config.pro file as CREO Parametric, I though it uses the same dtl file as well ...
Any idea ?
Mathieu,
please ask PTC Support. Your question must be easy to answer for them .
MH
Martin Hanák
gkoch
(To:msauthier)
Interesting question!
When you receive an answer by a PTC TS Case, please consider sharing it with the community.
Thanks!
Gunter
