CREO Won't Load
oklahn
CREO Won't Load
I just finished installing CREO Parametric 3.0 but when I try to open the program it does nothing. The load icon appears for a couple of seconds and then disappears. I have been looking online and maybe I don't have compatible hardware? I'm currently using Windows 7 Home Premium 64-bit. Any help would be appreciated.
9 REPLIES 9
Mahesh_Sharma
22-Sapphire I
(To:oklahn)
Otto,
It can be due to graphics on machine, try adding graphics win32_gdi in config.pro in <Install location>\M##\\Common Files\text
How do I open config.pro? Would I need a specific application?
Mahesh_Sharma
22-Sapphire I
(To:oklahn)
you can open that in text editor (notepad or wordpad)
There is a prompt that tells me "Access is Denied" when I try to save the config.pro file.
Mahesh_Sharma
22-Sapphire I
(To:oklahn)
Yes, you may need write permission to save that file. Other options:.
Ist:
1. Right click on Creo shortcut > Properties
2. Check the Start in folder
3. Open start in folder in Windows explorer
4. Create a text file and change the name of file as config.pro
5. Open the created config.pro and add defined option > save and close.
IInd
2. move the cursor to extreme right in target part and add a space after double quote and -g:win32_gdi
Every time I tried opening the program it would create "_trl.txt" in the "Start in:" folder which in my case is C:\Users\Public\Documents. The two options didn't work for me but when I clicked on the "_trl.txt" file, the program PTC Creo View Express starts up.
MartinHanak
(To:oklahn)
  • launch Notepad using right mouse button command Run as Adminstrator
  • open config.pro file and add graphics win32_gdi option at the end of file
  • save file
MH
Martin Hanák
BenLoosli
(To:oklahn)
Is this a commercial version or student version of Creo 3?
Open up the permissions on the <Install location>\M##\\Common Files\text folder so you have RW rights.
Do you have the proper license file for Creo 3.0 and the License Manager installed?
I have a student version of 3.0 and I entered in the license that was given to me by my instructor. I had installed everything successfully without any prompts. I just allowed permissions for all users on the text folder but it still won't start.
