CREO2 Issue
BrianToussaint
CREO2 Issue
Just rolled out CREO2 and have 1 user with an issue. CREO froze on them and they killed it. Now CREO gets stuck at the Retrieve Previous session screen. It will not let us retrieve or cancel. I am guessing there is something that needs to be deleted, but I just can't find it.
Thank you,
Brian Toussaint
CAD Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
Phone: (770) 487-2331 ext. 1216
Fax: (770) 487-3359
www.hoshizaki.com
Thank you David. I deleted the users .wf folder and the problem went away.
David suggested to only try deleting the files .wfwsi2008 and .Settings/active_serve_config.fid. Since the user didn't have any work to lose, I just got rid of the .wf folder and set them back up.
Thank you,
Brian Toussaint
CAD Administrator
I also saw this issue when we had the imbedded browser set to Mozilla_based. As soon as it was switched to ie_in_sep_process it was fine as well.
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.951.0168
website www.daktronics.com
We had the same problem with Mozilla based browsing, but wanted to keep that for Windchill performance.
We disable the session retrieval by setting the config option: last_session_retrieval no.
/Bjarne
I am looking for a batch file that when run, will:
Reboot the PC, then run defrag.
Thanks.
~Doug
XP Service Pack 2
