Can Attribute "PTC_WM_LIFECYCLE_STATE" be used for publish rules?
Our requirement is to generate the EPMdocuments once the drawing is published through post-publication using publish rule.
Particularly, it should post-publish only the drawings which are having PTC_WM_LIFECYCLE_STATE=Released.
However, when created a PublishRule.xml with below lines it does not work. Drawing withPTC_WM_LIFECYCLE_STATE=Released are not getting post-published.
It does not consider value for parameter:PTC_WM_LIFECYCLE_STATE and post-publication does not happen.
<rules xmlns="</span">http://www.ptc.com"
xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http://www.ptc.com
PublishRulesSchema.xsd">
<authoring-application name="PROE">
<epm-iba iba="PTC_WM_LIFECYCLE_STATE" value="Released">
<publish on="checkin" param-set="Post" publish"="/>
<publish on="create-representation" param-set="Post" publish"="/>
<publish on="schedule" param-set="Post" publish"="/>
</epm-iba>
<param-set name="Post" publish"=">
<post-publish name="delegate">com.ptc.wvs.server.publish.EPMPostPublishDelegate&l
t;/post-publish>
<post-publish name="type">wt.doc.Document</post-publish>
<post-publish name="name">{EPM_NAME}_temp</post-publish>
<post-publish name="number">{EPM_NUMBER}_temp</post-publish>
<post-publish name="published-content-link">create</post-publish>
<post-publish name="container-oid">wt.pdmlink.PDMLinkProduct:79086986</post/> -publish>
</param-set>
</authoring-application>
</rules>
