Hi Everyone,
I see that the config.pro uses the $PRO_DIRECTORY environment variable. My question is can it read any variable that I define? If so, in what file would I set it so it would be read? The proe.bat or proe.psf? Does anyone have a working example?Hello Dave,
Really useful information, and it really works. I Set a "Creo_Lib" user variable and give it a path value, and use it in config.pro, to instead of those directory path, if i move all the lib folders i just need to change the "Creo_Lib" value.
It saves me a lot of time.
Thank you.
Jeff
