Can someone help me?
ptc-2521027
how do you check what the license feature version is? I keep running into the problem where it says License request failed for feature PROE_Student Edition4:-2: Invalid license file syntax. If you couldexplain to me what I need to do so I can use my program it would be greatly appreciated!
Lonnie, Not sure if this is what you are looking for, but if you look under the Help pulldown, pick on the Technical Support Info selection. In the window that comes up it will show your License Version.
