Can't launch Wildfire on windows 7 machine from network installation.
LEONIDGUREVICH
I can't launch Wildfire2 (and WF5) from network installation on new client machine with Windows 7 (SP1).
After starting - Wildfire open with error: "License request failed for feature PROE_Flex3C:-57. Socket() call failed.Warning: Proper TCP/IP configuration was not detected..." and crash.
I copy installation to local disc and Wildfire start here without error.
We have other computer with Windows 7 and I can start WF here from ??network installation without problem.
???Has anyone else encountered a similar problem? If so, did you find a solution?
I currently run Wildfire 5 as a network install with no issues. My Workstations are running Windows 7 SP1 64-bit and the Network Server is Windows Server 2008 64-bit.
I don't think WF2 is supported on Windows 7 but I could be wrong. Maybe it's the 64-bit support. WF5 64-bit runs great on Windows 7 64-bit.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
