Can the Creo license manager be for 3.0 and the client machine run Creo 2.0?
vfrauenfeld
Are we able to upgrade the license manager to Creo 3.0 and have client computers that still run Creo 2.0 and point to that same license manager. In other words, is the license "Backwards Compatible"?
I would like to upgrade the license manager to Creo 3.0 and install 3.0 on a few computers to test. However, most users will still be using 2.0.
I want to know if the computers that have not been upgraded can still use the same license manager if it is upgraded.
Vic
HI Victor,
Yes, you can have a newer version of the license file and server, but still run an older version of the software.  They are backwards compatible.
Amit
BenLoosli
(To:vfrauenfeld)
I have installed my Creo 3 license file on the license manager that came with Creo 2 and that works fine.
I would imagine that the Creo 3 license manager and license file will work for your Creo 2 users without problem.
I am running FlexNet Publisher 11.11.1.
HI Victor,
Amit
