Can you create visible areas of views with shapes, or datums, or does it have to be splines?
CB_10360912
3-Newcomer
I am using Creo Parametric Release 9.0 and Datecode9.0.4.0
Is there a better way to create a visible area on a view using shapes, or datum planes rather than just using splines that you have to free hand draw?
Another question I have, is when drawing with splines, can you create a hard, one point turn if you're trying to create a square for example?
Dale_Rosema
(To:CB_10360912)
Unless things have changed recently, splines are the only option.
The longer the distance between Pt1, Pt2(the "corner"), & Pt3 the sharper it will be, but you cannot get to a square corner.
Dale_Rosema
(To:CB_10360912)
StephenW
(To:CB_10360912)
StephenW
(To:CB_10360912)
