I have installed two Windows 7 64bit machines with Wildfire 5 ( also tried 4) pointing to the same license server with a current MECHANICA license. One machine works in both standalone and integrated mode and the other will not. Ideas?
Here is the solution (THANKS BRUCE ROWITS!):
Error "Unable to get required Mechanica license please contact your sales rep" when accessing Mechanica as application in Pro/ENGINEER
Description Error "Unable to get required Mechanica license, please contact your sales rep" when accessing Mechanica as application.
Applies To Pro/ENGINEER Wildfire 4.0
Creo Elements/Pro 5.0
Cause Error may prompt due to multiple reasons, as:
Resolution Resolution based on possible reason, as:
