Cannot find ANSYS solver
MikeBills
We are fairly new to Mechanica. I personally have never used the
module. Our sole Mechanica user gets the following warning when trying
to run a simulation.
"Cannot find ANSYS solver, check installation"
Is this something that might be found on the install disk or is this a
separate module that needs to be purchased? Is this a setting that must
be altered to work? Any information on this ANSYS solver would be
appreciated. Sorry for the ignorant question with limited info.
Thanks.
WF3 Build M100
Mike Bills
Ingersoll Cutting Tool Company
Rockford, IL
2 REPLIES 2
Mike,
I think you are in FEM mode, which is a pre-processor to use other
solvers such as ANSYS. You need to be in Mechanica Structure mode
without checking the FEM check box so you can use the Mechanica solvers.
Dana
e
SPINE
Dana Coombs
Analytical Engineer
1301 Goshen Parkway
West Chester, PA 19380
MessageMike,
When installing ProE, you must choose the folder where you installed MECHANICA. You do not need the CDs to fix this. Just run the ptcsetup script and look for the page that asks you about other applications.
Randy Speed
President, CEO
Speed Consulting, LLC
www.speedconsulting.com
