Cannot install Creo after moving license host
EN_10350239
I am using Pro/ENGINEER and Creo Elements/Pro Release 17.0 and Datecode96130
I changed the license host from a computer that died to the new device in the PTC licensing management website, but am having issues installing Creo with the new licensing information. I saved the license.txt file to the new device and it keeps telling me that the license server is not reachable, despite the fact that the license server is the local computer.
2 REPLIES 2
I'm afraid no one can help you with Pro/ENGINEER Release 17.0.
Martin Hanák
It is not really clear to me (or the community) which CAD product you are using / would like to use.
  • Pro/Engineer
    or
  • PTC CoCreate Modeling Version 17.00 / Creo Elements/Direct Modeling 17.0 Mxy
If the latter one and you have installed the MELS on your local computer: what is displayed at http://localhost:17171/ ? Does it look okay?
If your problem has been solved in the meantime ..  please mark the thread / the problem as 'solved'
● PE80+90@home ● W10 Pro Build19045.6466 ● Drafting 20.6 + Modeling V20.6+7 + Windchill 12.1.2.6@job ● brain 6.3 ● Stift+Zettel V8.42
