Caret character in ptcstatus output?
Invisigoth
I am trying to understand what a caret (a.k.a. a circumflex) character means in the ptcstatus output.  Using FLEXnet Publisher version 11.14.What does the caret mean?What does the caret mean?
I cannot find a reference for this either on or off the PTC site.
Thanks for any info!
@Invisigoth
That is an indicator for Borrowed license. If you will execute ptcstatus, symbol will display to indicate borrowed license. I am not sure, if this will be documented in License admin guide PDF as that is common for all applications.
@Invisigoth
Thank you Mahesh.
