I am trying to understand what a caret (a.k.a. a circumflex) character means in the ptcstatus output. Using FLEXnet Publisher version 11.14.What does the caret mean?
I cannot find a reference for this either on or off the PTC site.
Thanks for any info!
That is an indicator for Borrowed license. If you will execute ptcstatus, symbol will display to indicate borrowed license. I am not sure, if this will be documented in License admin guide PDF as that is common for all applications.
Thank you Mahesh.
