Change Notice Report
ptc-171472
Newbie
The default Change Notice report contains the following fields
Number, Type, Organization ID, Version, Name, State, Resolution Date,
Complexity
I don't need Organization ID, Resolution Date, or Complexity
I need to add the following fields/information
From Routing/Process History
Initiated By and Date Completed
From Routing/Process Status
Who was assigned the Promotion Approver role
The "Date Completed" for the Activity name "Approve Engineering order"
I have no clue how to go about this. Any and all assistance would be
greatly appreciated!!!
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator/Process Integration Specialist
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
I didn't get any responses the first time.
Can anyone offer some guidance on this issue?
Complexity
Any and all assistance would be greatly appreciated!!!
Michelle McMasters
