Is this possible? I'd like to set the color to black (purple is the default) and I looked for a config option to do so, but I had no luck finding one.
Hi Shaun,
In Creo Simulate 3.0, we enabled users to modify Simulate Entity Colors via the Options dialog (System Colors). See image below.
With this enhancement, you can set your own color preferences for Simulate entities and save them to be used in future sessions.
Hope this helps.
Mark
Have you found the color somewhere in the system colors (UI).
Not sure whether there is a config.pro option for every system color, but it probably is a good start.
Hi Shaun,
Hope this helps.
Mark
