Changing Units Globally
Newbie
How do I change the units globally (I'm guessing in config.pro), instead of having to change them individually for every new part?
RE: Changing Units Globally
pro_unit_length pro_unit_mass its in the help files, but better use start parts. Start parts should have datum planes, a coordinate system and all parameters you need. You could even assign a material file to them.
