Changing line lengths in a drawing? Elements direct 4.0
ptc-5460979
I am currently trying Creo Direct 4.0 and have a few issues with the drawing tools. If I draw a line or box and then subsequently want to change its length it seems that the only way I can do this is by dragging it out which does not allow me to set it to any length outside of the grid settings. So if I want to set a length of say 14.25mm the only way I can find to do this is by using the 2D split tool and cutting away the unwanted portion.
There must be an easier way to change a line length.
Can anyone help?
0 REPLIES 0
