Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We're planning on upgrading to WF4 over the next couple of weeks. We've been running WF2 on a network install and at times it is a little slow. After testing WF4 on the network install, it is painfully slow to load. Ideally, I'd like to "push" Pro/E down to each of the client workstations. I'm not sure what the most efficient method is to accomplish this. Can I simply copy the folder structure from the network to the client machines and point the shortcuts to the local install?
What is the best method for handling installing new maintenance releases? I want everyone to be on the same release.
Regards, Jeff Horacek Sr. Designer
[cid:735083218@09112009-1991] This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
