I have a problem, actually i'm using CoCreate 17.0 and it works perfectly fine until i start annotation modules, then the software crashes and i have to shut it down from task manager. No error message...
With CoCreate 16.50 there is no problem, it only happens with CoCreate 17.0 version. So, i don't know if the softwate wasn't installed properly or what.
For further information i'm using Windows XP.
Thanks in advance.
Can you provide some information about your graphics card and try the following:
Change the graphic acceleration from hardware to software.
Best would be to open a call with your value added reseller (Arion Data?)
Hans-Georg
