I know that I've seen this option somewhere but I can't seem to find it now.
It allows you to set opening the PTC browser upon open to no. Anyone remember what the command is? Thanks so much!
Actually, I was wrong there. That option hides the 3D model space tab. The correct answer is in Tools > Customize Screen > Browser, then uncheck "Expand Browser by default..."
enable_3dmodelspace_broswer_tab no
Thanks!
Have a great day!
Actually I figured that out two days ago - thank you!
