Config options
Ketan_Lalcheta
Config options
Hello all,
Is there some document which describe all options of config file along with its importance?
Thanks in advance...
Regards
Ketan
tivancso
(To:Ketan_Lalcheta)
Hello Ketan,
Yes there is a file that will show you all the config.pro settings, and it is available through the PTC eSupport portal.
Creo 2.0
http://support.ptc.com/WCMS/files/138511/en/creo2_m190_configoptions.pdf
Creo 3.0
http://http://support.ptc.com/WCMS/files/161471/en/creo3_m100_pma_configoptions.pdf
Thom
2 REPLIES 2
tivancso
(To:Ketan_Lalcheta)
Hello Ketan,
Creo 2.0
Creo 3.0
Thom
StephenW
(To:Ketan_Lalcheta)
Importance is going to be highly subjective.
There are many other hidden options that are not on the list that PTC provides.
I use Olaf Corten proesite.com to help with those. Some of the hidden options are explained, some are not.
Hidden options are usually fixes to a specific problem that are not supported by PTC for mass use. They are not fully tested and my cause other unexpected problems.
Search Pro/ENGINEER config.pro options
