Hello all,
Is there some document which describe all options of config file along with its importance?
Thanks in advance...
Regards
Ketan
Hello Ketan,
Yes there is a file that will show you all the config.pro settings, and it is available through the PTC eSupport portal.
Creo 2.0
http://support.ptc.com/WCMS/files/138511/en/creo2_m190_configoptions.pdf
Creo 3.0
http://http://support.ptc.com/WCMS/files/161471/en/creo3_m100_pma_configoptions.pdf
Thom
Hello Ketan,
Creo 2.0
Creo 3.0
Thom
Importance is going to be highly subjective.
There are many other hidden options that are not on the list that PTC provides.
I use Olaf Corten proesite.com to help with those. Some of the hidden options are explained, some are not.
Hidden options are usually fixes to a specific problem that are not supported by PTC for mass use. They are not fully tested and my cause other unexpected problems.
