Config.pro for realtime rendering in creo 3
fgeiskopf
Is there a config option to set to not display shadows on a transparent floor with the new Creo realtime rendering ?
3 REPLIES 3
In options>model display under real time rendering settings you have "Enable shadows cast from model onto specific room walls".
Uncheck it and you will lose shadows,
Thank you fo your answer. I have already found this entry in the options tabs.
I would like to know if there is an item in the config.pro (hidden or not) to set this by default (not enable shadows cast from model onto specific room walls).
Regards
l have found only:
real_time_rendering_display --- Set the realtime rendering to project shadows/reflections on a transparent floor. Default value: transparent_floor
Try to test it...
