Config.pro
Newbie
Config.pro
Hi, This is Dharmesh Here, I need a config.pro file for the Wildfire4 Can anybody help me out??? Thanks
Config Pro
Typcially the path would be C:\ptc\proe\text You should be able to find the Config.pro from this folder. -Chander
Look for one in your startup folder
After you fire proe, open a file and take a look at where it looks for existing files. It may probably be in that location. Regards,
RE: Look for one in your startup folder
i mean to say, I need the ready file which i can load it to my directory & use it
Use earlier or Create
Dharmesh, You need to create config.pro files.There is no standard for it. You can use the earlier one from Wf2,3.. Or you can create your own based on your requirements.. That can be done by #Tools >>Options. Then add the options and save the file as config.pro (not as current_session.pro) to text folder in your Pro/E loadpoint or your start in folder or your home directory. Rameet
