Configuration Creo 7.06 Hole, Specifications
WD_10959322
2-Explorer
How (where) could I find in my configuration of hole the following specifications for a Kato hole?
The problem is you can find them in Creo but not in the Hole-configuration.
  1. (Core) Drilling depth DRILL_DEPTH
       2. Thread depth THREAD_DEPTH
       3. Thread length THREAD_LENGTH
Thanks, in advance.
Djiki Wilfried
Hi @WD_10959322,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
TomU
(To:WD_10959322)
  • The hard coded predefined rules are :
    • DRILL_DEPTH = 3 x DRILL_DIAMETER
    • THREAD_DEPTH = DRILL_DEPTH / DEPTH_RATIO
    • DRILL_DIAMETER and DEPTH_RATIO are 2 values available in the .hol file
CS99906 - Is it possible to directly specify the "THREAD_DEPTH" or DRILL_DEPTH values in a .hol file in Creo Parametric (ptc.com)
Add thread depth and or drill depth to .hol hole f... - PTC Community
