Conflicting License Keys
areed-2
I have conflicting license keys on my desktop at home, I just installed Creo 3 with a new set of license keys and my old ones expired. It does not work anymore for some reason, the error that comes up says a lot about licenses and redirects me to a folder which is where the keys are stored. I deleted the old ones manually in the file folder, but the same error pops up again, just with a much shorter message and the same directory, even though the old files are gone. Could someone help me with this as I desperately need to work on something before Monday (3 days).
in your license file there is a line beginning with keyword INCREMENT. License name is located after it (as second word on the same line).
MH
Martin Hanák
7 REPLIES 7
please upload your license file, if you want me to help you. Use How to attach file when you Reply to a discussion. procedure.
MH
Martin Hanák
How can I send this to you privately? I'd rather not make my license public.
locate parametric.psf in Parametric\bin subdirectory of your Creo installation. Open it in Notepad and check/modify following lines according to your current license file.
ENV=PTC_D_LICENSE_FILE-=enter path to license file
ENV=CREOPMA_FEATURE_NAME=enter license name ()
MH
Martin Hanák
Where do you find the license name?
MH
Martin Hanák
Thank you very much! It works now
BenLoosli
(To:areed-2)
Did you load your new license file into the license manager?
Did you modify this line in your license file?
DAEMON ptc_d __PTCD_PATH__
Like Martin said, modify the parametric.psf file.
