Cosmetics features show through solids
ShandRonnie
Hello friends at the Exploder,
ProE 2001:
We have many models that have the part numbers or special codes modeled
with a cosmetic feature.
The problem is that at a higher assembly you can see many of these
cosmetics thru the solid models because of the nature of the cosmetics
that do not blank behind a solid model.
Is there a config.pro that will make the cosmetics hide behind solids or
behave like a datum curve?
I do not want to layer them out because they are important data that
always needs to be there.
Personally I do not use cosmetics for the above stated reason; instead I
always use datum curves.
I am sure that this must be an intended functionality, but I do not like
it.
Ronnie Shand
I make them all go to a layer and hide them.
