Creo 1.0. Platform support
VladimirN
Hello!
So, i look at "Hardware Notes - Creo 1.0 Parametric, Direct and Simulate". And there is no support for Windows Vista (32 & 64 bit). Does the PTC support for this OS in the future release, or even updates (build) for 1.0? Any comments? Thanks.
Hello Vladimir
A few minutes ago I installed a Creo 1.0 on Windows Vista 64bit OS and everything is OK.
Good luck with Creo 1.0
Have a nice day, Vladimir
Best Regards,
Vladimir Palffy
Hello Vladimir
Here you can find Platform Support for Creo 1.0: Hardware Notes - Creo 1.0 Parametric, Direct and Simulate
Vladimir
Note: If it is not supported does not mean that it can not be used . Use and enjoy it.
Best Regards,
Vladimir Palffy
Vladimir Palffy wrote:
...Note: If it is not supported does not mean that it can not be used . Use and enjoy it.
Vladimir,
Thank you for your comment. This PDF file, I just looked. But have you tried to install and then run Creo 1.0 on Windows Vista?
P.S. Unfortunately, I do expect my license Creo, so I can check it out.
Hello Vladimir
Best Regards,
Vladimir Palffy
Thanks!
Note2:
See in the document:
Creo 1.0 does not support Sun Solaris 10 or Microsoft Windows Vista
Vladimir
Best Regards,
Vladimir Palffy
