Hello
I ran the setup.exe file and i get this error message:
V:\pim\x86e_win64|installmgr.dll is either not designed to run or Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0xc0000020
Does the setup has to be installed in the desktop as opposed to a mount drive?
I am not sure if is the dll file itself or my Windows 11 (i do have window universal c runtime as MS visual c++ Redistributable). I read somewhere here to download the dll file for creo 2.0 but i havent seen one for creo 10. I am still on the fence if it could be something else
thanks
@joe_c wrote:
Hi Martin
Q1: Not my first rodeo, last install was 5 years ago in an old laptop that i dont have
Q2: Lenovo i9-14900HX, 2.20GHz, 32 GB Ram, Windows 11 v. 24H2.
i run the setup.exe as admin or regular user and still fails pointing to the installmgr.dll file
my suggestion ... do not use disk V:.
Q1: Is this your first Creo installation?
Q2: What is the hardware configuration of your PC?
Hi Martin
@joe_c wrote:
Hi Martin
