David: I downloaded the excel spreadsheet but cannot open it in excel. It says that the file extension deoes not match the content. Can you reload the excel file? Perhaps in an older format?
I had the same problem. It is a .png file despite the .xlsx extension.
In Reply to Charles Wenning:
PTC quality philosophy: We've upped our quality standards. Up yours.
Mucho Gracias, Mr. Haigh!
David,
This is fantastic. I really do appreciate the effort you put into doing this.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
Much better, the zip file worked great. This is great. Much better than PTC's list.
Great work David. Found this in a recent search.
Is the "allow_create_pdm_param yes" no longer available in Creo 2 or 3? Using PDMLink.
I used that more than I should have in the past.
Kevin
