I would like to get confirmation on the issues regarding Creo 2.0 F000. I am hearing that it's not possible to un-install it correctly. Is this true for the web install version or is this a problem with the full download installer as well?
Has everyone experienced this issue or is it isloated?
I am running Windows 7 Pro 64-bit if this helps any.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
Thanks again David.
This makes it difficult when I install it on a Network server, so I better hold off from doing that and just install it locally.
For those who may have installed more than one application throught the F000 installer, note that you have to do this for EACH of the application uninstallers. So, once for Parametric, then for Layout, then for Simulate, and so on...
In Reply to David Haigh:
See the attached emails for the solution
David Haigh
It seems that F001 is now available which solves the install issues. This is what I ended up installing.
