Anyone else having the issue of Creo 2.0 F000 loading just the splash screen and nothing after that? I can't even get the program to uninstall because it gives me an error.. Are there any workarounds for this or is this just me?
See https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS58765 to uninstall.
Thank you Very much Joe, worked like a charm. I tried searching the solution database for a reason as to why it won't boot up. Is this a comman problem with people right now? Trying to figure out if it's the software or my machine. I know the F release codes are wishy washy, but I have also seen how people have gotten theirs to work..
Took me a while to get Creo Parametric 2.0 to work yesterday. I had to redownload the installer from PTC's website cause for some reason it got corrupted during the download.
Well that's a try, I am downloading it again to see if that was the reason. Will update if the re-download fixed the problem.
So I tried to re-dowload it and still no luck getting it to load past the intial splash screen. Guess I'll have to wait for a date code to come out to give this thing a go.
Ahh, bad luck, sorry.
What is the initial splash screen that you mean?
So far I've less issues with Creo 2.0 F000 than I've had with Creo 1.0 M020 or M030.
Any idea how to unistall on a 32 bit platform. (Can not find a file called pimunistall.exe.
I am on Win 7 64 bit and I can find it here
"C:\Users\Admin\AppData\Local\Temp"
John,
you can try this:
Good luck
Martin Hanak
