Creo 2.0 License problem
ptc-3934580
I am using a Creo 2.0 with floating license from a server. Sometime Creo 2.0 get crashes due to the errors than the license get locked into my system.
Even I am not able to the license in my system again. Anyone knows how to release the locked licenses
Open a command prompt at \..\Creo 2.0\Parametric\bin (hold down the shift key and right click the folder in windows, select open command prompt here). Type ptcstatus. Look for your user name and find your port (i.e. 7788) and handle numbers as well as the feature and license server.
Then type in another command window or the same: ptcflush [feature] [license server] [port] [handle]. The license will be released.
Sounds like you need to adjust the timeout (or whatever it's called) for the licenses.
