Hello, sorry for my english if i make mistakes.
I have an issue with Creo 2.0. I installed the full package, all good, except Parametric.
Seems to run, the first window appears
Then nothing... Doesn't open ...
Creo Simulate, or others programs from Creo works.
Please help quickly. I have deadlines for this week.
I need help step by step because i'm not so good with this software.
Many thanks!
I installed successfully Creo Parametric on other Windows... so it's a problem with Windows 8.1.
Thanks anyway!
What OS are you installing it on?
What graphics card does your computer have?
Thanks anyway!
Don't forget to mark your answer as correct for those who may have the same problem.
Even I have the same problem.Creo parametric alone not working.Just it Opens and closes.
OS: Windows 10 pro
Graphics: amd rx560x
Pc: Acer nitro 5 AN515-42
