Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Is there a config setting that will force the measure dialog to be fully open every time?
I want this:
[cid:image001.png@01CE4028.D1650090]
Not this:
[cid:image002.png@01CE4028.D1650090]
-- This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Another annoyance with this form is when the results show up under the Measure Summary form. I'm constantly moving the form out of the way to see the results that are stuck in the upper right corner. Of course, this is when the form is not fully expanded where I can otherwise see the results. But when I want a quick measure and I have to move the form, it drives me nuts.
Anyone else see this?
Dave Clark Sr. CAD Application Engineer Dukane Corporation Intelligent Assembly Solutions Division 2900 Dukane Drive St. Charles, IL 60174 630-797-4922 (Phone) 630-797-4949 (Fax)
