Creo 2 will not launch
cjohnstone
3-Newcomer
All -
Thought I'd start a new thread because this is probably a dumb question compared to the rest of today's discussion:
I have auserfor whom Creo2 (M070) will not launch at all on(new installation). xtop.exe fails before we can even get a session open. I've tried reinstalling to make sure nothing weird was selected during the process, but still no-go. This is the only machine it's happened on (so far).
Any ideas what might be hanging it up or where I should be looking?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
6 REPLIES 6
BenLoosli
(To:cjohnstone)
My first guess would be graphics card/driver.
List the machine specs for that machine, please.
Have had this happen before. Always ended up being incorrect system
environment variables.
davehaigh
(To:cjohnstone)
Could it be looking at an old cache file? Or a corrupt cache?
Even if you don't connect to PDMLink Creo/ProE uses a cache, that's where it stores your favorites etc.
The default location is:
%AppData%\Roaming\PTC\ProENGINEER\Wildfire\.wf\.cache2008\
Just move everything under ProEngineer to a different location, so you can restore it later if you need, and try again.
If your using a custom startup script, the startup command in creo is different than ProE.
start "anything-here " "<path goes=" here=">\parametric.exe"
David Haigh
Checking variables against my own now, but machine specs are:
Intel Core i5-2500 CPU@3.30<">mailto:CPU@3.30> GHz, 8 GB RAM, 64-bit, graphics card ATI Radeon HD 4300/4500
Thanks for your help, everyone. I still have a few of your ideas left to try/check but am moving on to other crises for now - I thought the cache file would be the winner after I found and moved about 4GB of cache.... Grr..... but still no dice.
May still be a permissions issue - I need to drag I.T. into it now.
Thanks again -
Chrystal
Thanks to everyone for all the help on this -
I ended up logging a call with PTC, and we discovered it was a graphics issue after all. For now, we are bypassing it by adding the syntax "-g:win32_gdi" to his target for launch. We'll need to replace his graphics card eventually, but for now he is up and running, so I'm happy.
Thanks again -
Chrystal
