Creo 3.0 crashes while saving drawing into DXF.
sbapat
7-Bedrock
Does anybody else have the same problem??
Not just this, Creo also crashes frequently while handling complex data.
Any solution?
sbapat
7-Bedrock
(To:sbapat)
Checked with PTCSupport, Just Version specific issue. M030 did not have any problem saving into DXF.
5 REPLIES 5
Mahesh_Sharma
22-Sapphire I
(To:sbapat)
Is this a reproducible exit with a specific data or with any of the data?
You may try latest datecode of Creo 3.0 or submit a case for Tech. Support with data and steps to reproduce the exit.
TomD.inPDX
(To:sbapat)
I regularly export DXF out of Creo 3.0 M020 drawings.  No issues at all.
Mahesh_Sharma
22-Sapphire I
(To:sbapat)
Sanskar,
Any update on this? Did you try contacting support on this issue?
sbapat
7-Bedrock
(To:sbapat)
Mahesh_Sharma
22-Sapphire I
(To:sbapat)
Sanskar,
You may mark your reply as Correct answer for the post.
