Creo 3.0 crashes while saving drawing into DXF.
Does anybody else have the same problem??
Not just this, Creo also crashes frequently while handling complex data.
Any solution?
Checked with PTCSupport, Just Version specific issue. M030 did not have any problem saving into DXF.
Is this a reproducible exit with a specific data or with any of the data?
You may try latest datecode of Creo 3.0 or submit a case for Tech. Support with data and steps to reproduce the exit.
I regularly export DXF out of Creo 3.0 M020 drawings. No issues at all.
Sanskar,
Any update on this? Did you try contacting support on this issue?
Sanskar,
You may mark your reply as Correct answer for the post.
