Creo 3.0 distributed batch
sammy1994
11-Garnet
Im trying to convert my drawing file which has 10-12 sheets into pdf/dwg format with each file having a unique name depending on the sheet no.(contents in the title block).
1.Is it possible to create a separate pdf/dwg file for every sheet
2. Can the renaming of the dwg/pdf files be automated??
Is it possible to somehow link the title block and renaming of the converted file by using AutoIT??
Im using creo distributed batch for creo 3.0
0 REPLIES 0
