Creo 3.0 slow performance, helping
uumut
Hello friends,
I am getting very low performance from my PC., especially drawing.
Is there a problem that occurs from creo? or Is my computer?
Note: I'm sorry to ruin my english
window all updates are complete.
Model Dell Precision T7910 (v2) Workstation chassis / chipset in 1300 (90%) Watts Vertical Box Intel C612 chipset PROCESSOR 2x Intel Xeon E5-2637 v3 (8 Core) (3.50ghz, 15MB, 2133mhz) RAM 32GB DDR4 2133mhz (ECC 8x4gb) (up to 1TB) Graphics Card NVIDIA Quadro K4200 (4GB GDDR5 256bit, Professional 3D) Hard Drive 1 x 256 GB SSD 500X550 OPTICAL DRIVE 8x DVD +/- RW Slimline Keyboard / Mouse DELL, keyboard, Dell USB Mouse OPERATION SYSTEM Windows 7 Pro 64bit MONITOR 27 "ASUS HDMI 1 AD
1 REPLY 1
gkoch
(To:uumut)
Slow is an impression, which is relative and strongly depends on the expectations.
Do you have comparison times with older releases or with other PCs?
Or specific steps that need significantly longer than you would expect from the changes/action they are supposed to apply?
Of course the size of the model/drawing has a strong impact (memory used, number of entities on screen...).
A general issue with large drawings often is time spent on pre-highlighting - to check whether it is related, simply disable it for testing (under File > Options > Selection)
