I am using Creo Parametric Release 3.0 and DatecodeM140
i need a installation for Creo 3 - M140. Can you send me the weblink for the download please?
Thank you.
The customer closed maintanaince when it was created Creo 3-M140. After crashed his computer he need new intallation, he can not copy installation and he can not instal newer version, because that's a violation of the license terms. But i am got a installation from the PTC support now.
Thank you guys.
Log in to PTC support portal at https://www.ptc.com/en/support
Then scroll down to download software.
Choose creo parametric.
You will likely only have the option to download the latest buildcode, not a specific build code like M140, this won't matter as any build code of Creo 3 will be fully compatible.
in the download software is just most recent version...M190. I need M140. All versions have just last versions Creo..7,8,9,10..
Regards
Why do you have to have Creo3-M140? All files created in any build of Creo 3 can be opened in any other build of Creo 3 (and newer versions of Creo). PTC only maintains distribution of the last build for all out-of-date Creo versions. You can download specific builds for Creo 7 and later, but not the older versions.
@BenLoosli is 100% correct. There is little to no valid reason to request a specific build code.
If you have a support account with PTC or access to a VAR, you can call them and ask for a specific build code. They MAY be able to help you. Creo 3 has been out of support for several years so you would have to work really hard to make it happen (and it may just not happen)...or just utilize the available M190 build that is available and fully compatible with M140.
if you have installation on computer no.1 and you want to have it also on computer no.2 then you can copy installation from computer no.1 to computer no.2.
Thank you guys.
