Creo 3 date code M100
Sreemesh
6-Contributor
dear all;
currently I am using creo 3 date code M30 for design and manufacturing (CAM).
I have a plan to upgrade this to date code M100.
is there any issue with M100 in manufacturing module ?
if anyone know-please tell me what are the plus and minus of M100 compared to older version.
thanking you in advance
FlorianHammrich
(To:Sreemesh)
Hello Sreemesh,
if you login with your PTC-account you can compare two releases and look for bugfixes and/or enhancements. I will send you an excel table with the data.
Florian Hammrich
B&W Software GmbH
RaphMORIN
(To:Sreemesh)
The main change between these versions is that Moduleworks is used for simulation instead of Vericut.
If you want a complete list of the changes you can use the update advisor page => https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
Sreemesh
6-Contributor
(To:Sreemesh)
dear;
thanks for your reply
I am unable to access the link you given ..
FlorianHammrich
(To:Sreemesh)
Hello Sreemesh,
Florian Hammrich
B&W Software GmbH
than you sir
