Hi all, i thought i had figured all this out when i first installed Creo 3 over a year ago. Recently i installed the M70 date code & now i am back to square one. Basically, i am trying to make A3 prints of my drawings that are typically A2 & A1 drawing sheets, sometimes portrait, sometimes landscape. It took me ages & alot of paper, but by changing the paper size to custom, & always having landscape orientation selected i got there. I made mapkeys that worked fine until i installed this new version. They still work, but not correctly. My A2 drawing is not being shrunk to fit my A3 sheet of paper in my printer, i end up with a 1/4 of a drawing. I do not remember all the settings I messed around with first time around but i don't remember ever messing with the scale. Can anyone help?
Regards
John
I am sorry I cannot offer you the solution of your problem. I guess it would be better to save drawing as PDF and print it from PDF reader.
MH
Hi Martin, that is what I did this morning to get the prints I needed.
John
