Hi Krzysztof,
1.) It looks like Creo 4.0 Trial is running in PTC Cloud.
2.) When I launch PTC Creo Trial Player >>> Creo 4.0 folder appears + Desktop Icons appear
3.) When I exit PTC Creo Trial Player >>> Creo 4.0 folder disappears + Desktop Icons disappear
4.) In PTC Creo Trial Player window I can start/stop Creo in cloud
Creo 4.0 for non-admin user
what is going on, when non-admin user launches Creo 4.0 trial ? Please attach some picture -OR- publish an error message.
Look into parametric.psf file ... find out where license file is located ... maybe it is saved in directory, which is not accessible for non-admin users.
Hi Martin,
during installation of Creo4.0, an additional software is also installed - "PTC Trail Player Powered by Numecent" (screen1.png). It acts as "virtual machine" - when you shut it down, you are not able to start Creo. What is more - shortcuts disappears form Public Desctop.
Creo4.0 in stored in default folder (screen2.png), and of course contains *.psf file. Strange thing is that license_file (C:\Windows\numecent_trial.txt) pointed in *.psf could not be found. Of course I've marked to show all system/hidden files in directory.
If you log as non-admin user Creo4.0 folder disappears (screen3.png), and Creo Trial Player is empty.
I understand that it could sound as science fiction, but it is true. When one of my customer inforned my about it - I did not believe him. But after making attempt by my own - I have to addmit that he is right.
If you have time please make your onw installation, and check. You will be supprised 🙂
regards
Krzysztof
Hi Krzysztof,
it means that trail version has to be instaled when proper user is looged. if you have 2 users on this same machine you have to download *CloudPlay.exe twice. I've tried to use backuped file from admin-user - without success.
But you are write - doing it in that way solves issue.
thank you
Krzysztof
